91 F-250 5.8 not running right
I purchased a truck that I had in the past and sold to a friend. He blew the motor up in it so we built a new engine for it and it never got installed. Sat on the engine stand in my shop for almost two years. I bought the truck back from him and got it back together. I have it running but it runs like crap and skips and pops when you try and rev it up. I have drained out as much of the old gas as I can and replaced it with new 93 octane fuel (6 gallons) I replaced the fuel filter, which has clear gas comeout of the old one. How can I tell if the Air Idle Circuit or the Throttle Position Sensor is bad. Timing is very close. I need to get this thing up and usable, I have already spent to much on it as is. Any help would be appreciated.
Thanks guys for the responces. I didnt even think to check the wires. I will do that. As far as rebuilt, everything new inside engine. Stock rebuild. All machine work done, Heads, crank, block. Distributor is a stock electronic ignition. Cam is hydraulic non-roller style.
Cam should be a stock cam with standard firing order for the 5.8. Everything was bought for the 89 5.8, the engine we built came out of an 89 Ford Bronco 5.8 4x4. I dont have the stuff that came with the cam. It was bought with the kit and everything came from the local machine shop that did all the machine work.
spiritrider1100
03-25-2012 11:23 PM
zukinut
24
08-24-2011 08:32 PM
ALSAIR
1978 - 1996 Big Bronco
03-28-2005 09:29 PM
zrtkicks
04-22-2004 06:33 AM
