Sensor on Rear axle
on
The VSS (Vehicle Speed Sensor) does a few things. It acts as a input to the ABS module to control the ABS for the rear axle. It also provides vehicle speed to the speedometer and helps determine shifting for the transmission if you have an auto. Removing this sensor, which I have done for troubleshooting an issue, will result in an ABS light, no speedometer input, and extremely delayed and hard shifts since it has to go on engine RPM alone to determine when to shift. On an '08 I cannot remember exactly how the ECU and the AT work together, someone with your year of truck could probably give you more specific info on that aspect of it.
Which sensor?
on
I believe the sensor for that is on the xfer case, however, dont' go replacing it yet though. I say that because there has been a few cases of some folks on here having that happen as well. I don't remember what the exact cause was, I don't believe it was a sensor though and it was a wiring problem. I'm sure if you searched the forum though you will find a few threads discussing it.
1995droptopz
1999 to 2016 Super Duty
07-15-2011 09:48 AM
66F100Again
11-16-2008 08:58 PM
matthew_thompson498
09-07-2003 06:33 PM
