Fuel pump is short in 50 Gall Titan tank
I just had a new 50 Gallon Titan tank installed in my 2013 Superduty F 350 with the 6.7 diesel and the dealer is telling me that the feed tube is short in the tank not reaching without pulling air about 15 gallons. Anyone else had this trouble and is there a fix?
It was installed by a Titan dealer but no-one mentioned the FUEL pickup tube was too short until the Ford dealer was fixing what the Titan dealer messed up. ( a Poorly installed fuel pump on the new tank caused water to get into the tank). After he was done and testing he heard noise coming from the pump (air getting in he said) and it wasn't until he put in over 10 gallons that the noise stopped. However shouldn't this lack of length on the pickup tube be mentioned on the Titan install process. I don't see it anywhere. The Titan 50 is definite deeper than the stock 25 gallon so the tube being shorter makes sense..
I spoke to James at Titan 208.522.1325 who was extremely helpful and will be pleased to be a resource for dealers installers and individuals needing help and info on Titan tanks. He too stated that the sending unit is mounted in a depression that compensates for the tank depth so reaching the total fuel capacity of the tank should n t be a problem . He also suggested that the noise the tech was hearing was from the retrun line and should not continue to be an issue. They also provided me with a MTE fix because the mileage remaining showing is still not correct. I'll take to the dealer with me to have them adjst. The analog fuel readout is correct.
Id be more concerned about water in the tank. Did the installer admit to that? Does your paperwork state installation error caused water to into the tank? Did the dealer get it out? Does it state none got theough the filter?
