Did any of the 400/351m engines run a saginaw type pump in the 80's trucks? looking for a bracket for a 400 ford upgrading to saginaw pump. will build but a factory bracket is possible will go this route. thanks from wyoming.
351M/400 cancelled at the end of the 1982 model run, cancelled at the end of the 1979 model run (cars). "Downsized" 1979 LTD/Grand Marquis not available with 351M/400.
1972/79 Passenger Cars with Hydro-Boost also used the "canned ham" Saginaw pump. 1975/79's were available with 351M/400's (except as noted above).
