1985 F250 302EFI Stalled Out !!!
Rebuilt injectors are on the way, to replace them are any special tools required? In my manual it mentions some special tool required to remove the injector rail. Do I need to try to locate one of these tools? I also ordered 4 hole injectors Bosh brand. They said they were compatable with the original ones in my truck. Thanks again everyone for coming to my rescue.
I haven't done mine yet, and won't get to it for a couple of weeks, but I think the tool they're referring to is the same tool to pull the lines off the fuel filter, and I think every other connection in fuel injected Ford's. This tool comes in a variety of styles (note attached picture). You'll probably need some of the little plastic clips to replace any that brake on you.
As I said, I haven't done mine yet, so I hope if I'm mistaken others will chime in and correct me.
You're welcome! Any auto parts store will carry these, or something like it. Some look very different from these, but all work to get under the line connector and push up on the inside circumference of a spring, which releases it from what ever it's attached to.
wesweav
09-05-2016 04:25 PM
earnhardtracer38
11-06-2008 09:08 PM
