Parking brake repair
I am trying to get the emergency brake working on a 1995 F350 CC 4wd psd and am down to the last part. I have replaced everything up to the rear where it should connect to the two rear cables. I was hoping someone could post a picture or give me an idea if I am looking for the right parts. I believe I need the adjuster, "equalizer" bracket, and a return spring.
Here is what I have now:
This is what I am working from to search for parts:
Thanks in advance for any info or help.
I have purchased these two, I'm hoping this will do it.
E Brake Adjuster Rod Assembly
http://www.ebay.com/itm/Ford-Parking-Brake-Equalizer-Assembly-OEM-BRAND-NEW-/320995965751?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AF-350&hash=item4abcd9bb37&vxp=mtr
I was thinking the same, but a little digging has left me thinking I need an adjusting rod in this location. The truck didn't have any hardware on it when I bought it, so I am flying a little blind, though.
If that is what your truck calls for, then it looks like the two links you provided should get you what you need.
I didn't need the adjuster rod on my truck even though it is listed in the link you provided.
My truck only had the equalizer on it, but a different one from your link. My equalizer had one side a bit longer with a slot to accept the cable that came from the cab.
Received 3,102 Likes
on
on
Yancy S
09-13-2018 06:18 AM
minist3r
07-21-2018 03:12 PM
bloydj
18
07-21-2012 09:33 PM
C-700
04-21-2009 11:16 PM
