88 ford f250 302 will not run
I am trying to get my step dads truck to run. it will run when you dump fuel down the plenum. we checked the fuel psi on the fuel rail it is @40 psi. i checked the power from negative battery terminal to red wire on the injector it has power. power however does not pulse when turning over. switched the ground clip to positive on the battery test light comes on and pulses when turning engine over. the gas gauge and the amp gauge also are not working. any help would be appreciated. Thanks in advance.
Dr. Johnny Fever
06-08-2016 09:27 AM
Johnny walker
07-10-2014 12:24 PM
