E4OD Leaking at Cooling Lines
Old Jun 9, 2013 | 11:17 AM
Norcalp's Avatar
Norcalp
There is some sort of inline cylinder, smaller than a small soda can that appears to be leaking. I can't find out what it is? It is located near the inlet/outlet solid lines. Any suggestions please?
Old Jun 9, 2013 | 11:25 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It probably is a filter that someone added. Those are common and there is nothing like that from the factory. You can remove it and splice the lines together.
Old Jun 9, 2013 | 12:32 PM
fordpride's Avatar
fordpride
Like Mark said it is a inline filter and most likely a magnetic filter. Those are mostly put in after a new/rebuilt trans has been installed. Just remove/replace it
Old Jun 9, 2013 | 12:43 PM
JWC 3's Avatar
JWC 3
^ x3 sounds like an add on filter .
Jimmy107
6.7L Power Stroke Diesel
Jul 5, 2017 10:05 PM
Studawg
Apr 10, 2012 02:06 PM
big_tuff
1997 - 2003 F150
Jan 24, 2007 10:17 AM
Turbodog1000
2004 - 2008 F150
Feb 27, 2006 11:06 PM
Oleblue74
Sep 27, 2005 07:01 PM
