99 f150 P0171
You have an important clue with the smell of gas.
Find the source and you likely will clear the code issue.
The code says lean but the basis for it is the fuel table has shifted to it's lean side, out of limits that sets the code.
The cause is likely the excess fuel you smell from a leaking injector or even a fuel regulator diaphragm leaking fuel through the vacuum hose.
Good luck.
Good luck.
