fuel smell
Old Jun 6, 2013 | 10:01 PM
mike L's Avatar
mike L
fuel smell
When I run the truck for a few minutes then shut it off. I can smell fuel from the engine area. I don't seems to smell it after a normal drive. There are no fuel leaks. It's as if there is extra fuel left over, at the top of engine.
I have bad fuel mileage, it may or may not be connected. Any fixes?
93 f150 5.0
Old Jun 7, 2013 | 12:19 AM
TexasGuy001's Avatar
TexasGuy001
Maybe its the vapor canister between the radiator and the battery. The purge valve could also be bad.
Old Jun 7, 2013 | 05:50 AM
mike L's Avatar
mike L
purge valve
Thanks Does it look like this, were about is it at?
Buy Wells Vehicle Electronics Purge Valve PV213 at Advance Auto Parts
http://shop.advanceautoparts.com/web...-bwd_3489884-p
Old Jun 7, 2013 | 09:05 AM
White Max's Avatar
White Max
The purge valve is located at the front of the engine, right between the EGR valve and the throttle body.
Old Jun 7, 2013 | 11:20 AM
mike L's Avatar
mike L
fuel vapors
Thanks, I'll take a look, or a smell.
1993 ford
24
Jun 25, 2017 11:22 PM
hop
Jan 27, 2008 08:48 AM
bhiggins
15
Oct 25, 2006 12:18 PM
crandall
Jul 23, 2000 12:13 AM
