Innercooler Pipes
Old Jun 3, 2013 | 12:01 AM
pilgrimbizket's Avatar
pilgrimbizket
Innercooler Pipes
So is there any recommendations of where to purchase pipes from?
I have tried the one gentlemen who offers a set with clamps for 200$.
But I have never heard a response.
Or should I just get some SD pipes and modify them?
Ive never welded pipe before, but I will learn.
Thanks
Old Jun 3, 2013 | 05:52 AM
427 fordman's Avatar
427 fordman
If you have a welder, they aren't hard to make. When I got mine I got 7.3 SD ones, and got one extra pipe to make 2 out of 3. If you do this, make sure you get ones that aren't aluminum. Some are, ask me how I know..
Old Jun 3, 2013 | 09:07 AM
mikec91's Avatar
mikec91
I went to a salvage yard got clamps and rubber boots
a thin drove to a good muffler shop had about 200 $
total
Old Jun 3, 2013 | 11:32 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Thanks
I used a SD pipes and some new pipes, no weld, just add some rubber boots here is a pic of mine (post # 41):
https://www.ford-trucks.com/forums/1...install-3.html
EDIT: Here is my IC install write up:
https://www.ford-trucks.com/forums/9...installed.html
Old Jun 3, 2013 | 01:08 PM
pilgrimbizket
Yeah I just purchased a welder and I really havent mig welded before. On top of that I have never welded pipe. But my local junkyard has a set of late 99 pipes, I need to call in confirm to see what they are made of thank you for the heads up on that.
total
So the muffler shop re bent and extended them? How did they come out?
Old Jun 3, 2013 | 01:11 PM
pilgrimbizket
Jose, did you use 6.0l IC pipes for the hot and cold side?
Thanks for the pictures and i really like what you did with the oil cap, nice work.
Old Jun 3, 2013 | 09:22 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
You are welcome, and yes I used that pipes for both sides. I didnt make any mod in the hot side (maybe I should weld a little piece of extra pipe there tho.), and in the cold side, is where I added some pipes and boots.
IF you are going to weld, I think is better, because in that way, there are less possiblities of leaks.
Uni Moe
Dec 16, 2016 05:15 PM
ghunt
Exhaust Systems
Nov 5, 2015 07:08 AM
Quill Gordon
Jun 27, 2009 08:14 AM
likwidsukr
Nov 5, 2004 08:41 PM
F0XR0D
Jun 28, 2004 03:54 PM
