1988 F-350 Build Thread
#91
You have 'print-o-seal' gaskets, they shouldn't need any sealant.
If you're REALLY worried about coolant leaks you might smear a THIN film of Ultra Black or some other kind of silicone around the water ports on both the head and intake.
The most important thing is to torque in steps following the recommended pattern.
Leaks are caused by uneven tightening.
I just got the torque pattern for my Stealth intake off of Summit's site, so I should be good to go there.
#93
Permatex 82180 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker, 3.35 oz. Tube : Amazon.com : Automotive
?Thanks
#95
#96
Yeah, it's coming along okay, but I've run into a lot of issues... It'll all get together though.
#97
#98
#99
Well, MPGs are going to suck with mine. The engine I'm working with is a 460 bored .030 over with a huge cam and ported D0VE heads. Plus the compression it's got will require high test gasoline. With the other 460 (1973) that I had in the truck with an RV cam and Stealth intake I could get up to 12 MPG on the dual lane @55-60 MPH with my C6, 4.56 gears, and 37s.
#100
With everything I've run into is just feels like I'm always getting knocked into the ditch every time I start making progress. Just how it goes.
Hopefully after I replace this intake manifold gasket and set the timing (again...) I'll be good to go.
#101
Tat 12 mpg is pretty dang impressive with a 460 and of all trans a C6. My friend has(had?) a 97 CCLB f350 4x4 with 35s and a 2"ish lift with an e4od and I think 4.10s, he said it gets 9mpg when he drives it good, 9 mpg when his girlfriend drives, and 9mpg when he floors it. Of course it has like 228,000 miles?
#102
I'm betting on like 7-8 mpg with this engine I'm working with now. I'll tell you after I get it up and going.
#103
#104
I'll probably buy a ranger or an f150 with a 300/stick/3.08s for MPG fairly soon. The 460 will be purely for play and maybe a heavy load here and there.
#105
I want to buy a nice running rcsb 300/5speed 4x4 for mileage after I'm out of school or if I start all the sudden actually making money(known as a JOB[which I don't have a real one yet]). I also want a set of 37" militaries for mine and eventually the 38" XMLs.
What else do you have planned for your beast?
