1996 F250 fuel filter install
on
The following 2 users liked this post by jas88:
You need a release tool for the line clips that slides in around the fuel line and into the filter to release the internal clips. Available at any parts store, unless you have the plastic "horseshoe clips" which just pull out. If you have those you should be able to see them on the ends of the lines. New ones usually come in the box with the new filter so you can see what they look like. If you have those you can just pry them out with a small screwdriver. Be prepared to plug or cap the fuel line so fuel doesn't drain all over everything. Also, a bucket under the area is helpful. Once you have the lines lose unbolt the bracket holding the filter to the frame, ( two nuts on the outside of the frame rail) now you can put the bracket in a vise and pop the filter out and pop the new one in. Much easier than trying to fight it in and out with the bracket on the frame. Bolt the new filter and bracket back on the frame, snap the lines back in and you are good to go.
on
The following users liked this post:
RNBinc
05-13-2020 11:17 PM
Chuckus
10-15-2018 05:52 AM
blindlightguy
02-21-2018 12:27 AM
1972fordhighboy2
06-02-2016 09:22 AM
