which rotors/pads do you guys use?
Old 06-01-2013, 07:21 PM
GuitarJesus's Avatar
GuitarJesus
GuitarJesus is offline
hey guys I could use some help. Most of the listings I find are either for four wheel drive or dual rear wheel trucks. I've got a 94' F350 with single rear wheel. What brand rotors and pads do some of you guys recommend?
Old 06-01-2013, 07:34 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
Originally Posted by FORDF250HDXLT
here's what i did;
1.hydroboost brake upgrade.click here:
https://www.ford-trucks.com/forums/1...st-brakes.html
2.dimpled and slotted brake rotors.click here:
https://www.ford-trucks.com/forums/1...l#post12533316
she stops incredibly better than when she left the ford plant in '93.brake performance increase was massive,making the safety level of the truck rise drastically.
with all that said,when you hook up to your trailer,your trailer brakes should be good enough to stop your load and truck.so personally i would start with your trailer brake system first then upgrade the truck brakes after.
Old 06-01-2013, 07:42 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Nothing but Ford or Motorcraft
Old 06-01-2013, 08:47 PM
MeanGreen460's Avatar
MeanGreen460
MeanGreen460 is offline
Napa break pads and shoes do a good job .Stay away from Auto Zone brake pads and shoes
Old 06-01-2013, 09:04 PM
GuitarJesus
I was thinking that Brad. But damn $100 for each rotor sucks.
Old 06-02-2013, 12:45 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
I'm just running cheap O'reilly rotors which have so far done much better than the expensive O'reilly rotors I had to replace after one year of use. I did step up to a midgrade brake pad though.
Old 06-02-2013, 03:22 AM
Golden Helmet's Avatar
Golden Helmet
Golden Helmet is offline
Since we're on the subject, I may as well ask here instead of making a new topic.
Do those fancy dimpled / slotted rotors actually make a difference in stopping distance, assuming no switch to hydroboost? My trucks braking performance is the butt of many jokes, and they're all well-deserved; compared to what I'm used to in a truck (my dads '02 Silverado 2500HD), the brakes are worthless.
I assume it's mostly because my truck weighs about the same as a third world country. The master cylinder is new and the system checks out perfectly. Pads and rotors have plenty of life left as well, I have no clue what brand they are but they're not fancy. I have no intention of converting my brake system, but I'm wondering if any practical gains can be had with the fancy rotors and pads.
Old 06-02-2013, 08:11 AM
FORDF250HDXLT
im not sure.they claim they do,but the main reason is to keep them cool so the rotors don't warp.i hate warped rotors.i warped my last set by using cheap rotors and good pads.i liked the aggressive pad and didn't want to go back so i took care of the issue with a lifetime rotor.
if you want real stopping power,nothing beats hydroboost.the vac system was not enough for my truck when i loaded her up and towed the chipper.you had to slow down way in advance and crawl to a stop rather than just stop when you needed.dangerous.if i went back and did it over,i would have done the hydroboost convert before truck was placed into service.night and day safety upgrade.turned the truck into doable to very capable.
you can do all kinds of things,but nothing is going to compare to the hydro swap.
Hydroboost Brakes
Old 06-02-2013, 08:58 AM
Diesel_Brad
Believe it or not, I would bet your dads truck weighs more.
All the holes and slots to is allow the rotors to cool faster
Old 06-02-2013, 09:53 AM
blkF250HD's Avatar
blkF250HD
blkF250HD is offline
I've got Wagner Severe Duty (fleet) pads on the higher end rotors, so far so good.
Old 06-02-2013, 10:33 AM
Golden Helmet
It'd be interesting to put both trucks on a scale. His has the 8.1l gas engine, 2wd, crew cab longbed with an ugly plastic toolbox on it (mostly empty), 28 gallon tank. Mine's the 7.3 diesel 4x4, extended cab long bed with a metal toolbox, light bar, and 45 gallon rear tank (plus the stock whateveritis front tank).
They're both massive pigs, that's for sure. But, when you throw in the Mark VIII, we've got Red-White-Blue in the driveway
5.0Torx
2009 - 2014 F150
04-25-2016 05:20 PM
JimiLL
08-02-2015 07:44 PM
bio-d
06-30-2013 10:26 PM
timo944
03-03-2013 01:43 PM
rhc43
03-23-2009 04:09 PM
Quick Reply: which rotors/pads do you guys use?
