What parts do I need for V8 swap?
Hey guys, newbie on the forum. I just bought a 1979 F100 with a 300-6. I'm wanting to start collecting the parts needed to swap in a 351W and auto, but need to now what all I need.
My dad told me I need: radiator, engine stands, throttle cable and mount, PS hoses and bracket, and a shifter if i put in an auto.
Anything that was missed? What can I get the engine stands from? Any other info or tips?
I look forward to all your guy's knowledge on this.
Add a V8 gas pedal crank to your shopping list. The I-6's pedal crank will be too far towards the passenger side.
Good luck finding or making headers work with the 351W.
Personally, I'd keep the 300 I-6... better gas mileage, torquey, lightweight, strong, and it responds very well to turbocharging (hint, hint!).
Thanks guys. The truck has the side shift 3+1 OD.
Will the engine stands from an Econoline van work?
The 300 is going to be in the truck for awhile as this is an "as I can" project. I mean it only has 91000 on it right now.
As far as headers go my dad used Hooker headers for a 302 in his '68. They fit fine except for a little interference on the passenger side.
on
1 Post
Engine stands no, gotta be from a v8 pickup. 2 or 4 wheel must match also. 351 is taller/wider than dad's motor. This pushes the primary tubes wider. They wont fit. My bro has the same set up on his 68. PO notched the top frame flange. Fail. A stock headed/cammed Windsor wont benefit that much from headers anyway, small exhaust ports, (bring on the flaming for that) use the stock manifolds and enjoy the sound of no leaks. Imho
gatorhater
12-07-2014 02:37 PM
v6lightning
11-03-2012 12:28 PM
dpoelstra
08-05-2002 10:29 AM
