Teapot 2bbl carb air cleaner
Need some help with identification of the oil bath air cleaner design, appearance, or "what it looks like" for this type carb. The carburetor is on a Lincoln Y-block & looks like this Holley teapot carb I found on ebay. The engine was installed in a 53' F350 express pickup replacing the original Flathead. Engine probably came from a Ford F700/800 "Big Job". I'm in process of buying the truck "long distance" and detail info is hard to get, but it needs an air cleaner & I'd like to find an original or similar if possible, as long as it fits/seals properly. The a/c bottom opening looks like it needs to be larger than the other y-block Ford/Autolite 2bbl carbs w/clamp rings. Need to know the opening i.d. and how it secures to the carb. A pic of the right air cleaner would be great. Thanks.
PEZLO
02-12-2017 10:17 PM
1956f350
06-04-2013 06:56 PM
mike01082
10-29-2010 01:17 PM
takid455
07-13-2010 08:00 AM
mossyoak1992
02-18-2009 06:47 PM
