Calling the 4r70 Gurus... Please tune in...
I have a 2000 Lariat xt cab 5.4 2wd. 4r70? I have a possessed trans. First off, the star gear press weld let loose and lost reverse, 2nd, 4th, and generally sounded and drove like .....(undrivable censored edit).... I had since had the trans rebuilt with new star gear, heavy duty disks and steel combo, etc. Ran great for about 3 months after the rebuild then lost OD. It would go through gears and when it should go to OD, it seemed to go to neutral. The mechanic went back in and said a gasket blew out and shredded. More $ for fluid and parts... Again, ran great for about 3 months. Now I have lost 3rd completely. The mech said that the bolts may have backed out on the valve plate. So I dropped the pan last night and made sure all bolts were torqued to 12 in Lbs., filled it up and still no 3rd. This knot in my stomach is tightening as I type . I truly believe that I have a gremlin that will take a flock of priests to excise. I don't really want to eat the $1800 loss on this trans and move on to a different one. But I need my truck to get to work, somebody has to make the donuts. lol. Is there a quick guide to cross-referencing tran swaps? Are some years better than other? Can I swap my 4r70 with a 4r100 out of a 2000 5.4 lightning and still use the same computer? Or maybe a 1998 E-250? What say the almighty Tranny Gurus?
Thanks for your help, my 150 would not have stayed on the road this long without all the advice and tips from this site.
Thom
Thom
It's not going to be of any help but you got a poor shop to do the work.
Any trans out of like year should work.
Just for illustration, I was pulling gross combined loads over 12,000 lbs and ballooned my converter with a 4.6L motor yet..
There was no use having it rebuilt stock and have the same thing happen again.
Went custom high performance rebuild from a very well known shop along with custom converter and never had a problem again. It's bullet proof and now has 190,000 miles.
Good luck.
Good luck.
Thanks Bluegrass,
I did find a 1999 E-250 that had a busted 5.4 and good 4r70 that was a rebuild about 60k (1yr?) ago for $200. I figure I can dig into this broken one and see what let loose, or in time find the right shop to hop it up.
Sorry for the repeat of the 4r70 thread, but I could not find a solid answer to what trans would work in my truck. I assume that the 99 e-250 will be a good match in theory. I still have not found a good 4r70 identification chart that would show if it were designed to be mated with the 5.4. I did find listing for year and what vehicle it came out of.
1999 and Newer Ford Part Number Codes
Example: XL3P-xxxx-xx
(1999, Light Truck, Automatic Transmission Engineering)
First Digit = Year
X 1999
Y 2000
1 2001
2 2002
3 2003
4 2004
5 2005
6 2006
7 2007
8 2008
9 2009
A 2010
B 2011
C 2012
D 2013
E 2014
F 2015
G 2016
H 2017
J 2018
K 2019
L 2020
M 2021
N 2022
P 2023
R 2024
S 2025
T 2026
V 2027
W 2028
Second and Third Digit = Vehicle Model
C1 Transit/v184
C2 Econoline
C3 Medium Truck
C4 Heavy Duty L
C5 Mustang
C6 Lincoln Blackwood
F1 Taurus
F2 Windstar
F3 Continental-FWD
F4 Sable
F5 Villager
F6 T-Bird
F7 EN158
F8 Martin
L1 Expedition
L2 Explorer
L3 Light Truck (F150-250)
L4 Maverick 4X4 (F250>8500 GVW)
L5 Ranger F900 &B Series
L6 Aerostar
L7 Navigator UN173 Series & Cargo
L8 Tribute/Escape CF Series
M1 Tracer
M2 VX62FWD MPV
M3 Courier J97
R1 Aston
R2 Falcon
R3 Mustang
R4 Scorpio
R5 Fairlane
R6 LTD
R7 Not Assigned
R8 Jaguar X200
R9 Mark VIII
S1 Aspire
S2 Contour
S3 C212MAV
S4 Escort/CW170
S5 BE146
S6 Fiesta/BW153
S7 Mondeo/CW132
S8 Probe/SW164
S9 Mystique
W1 Town Car
W2 Cougar
W3 Grand Marquis
W4 Lincoln LS
W5 EW171
W6 T-Bird RWD
W7 Crown Vic EM114
W8 Jaguar X100
W9 Jaguar X300
X4 Jaguar X400
Forth Digit = Engineering Group (as I understand, All will have code P for automatic)
A AVT Core Operation
B Not Assigned
C Chassis Operation
D Overseas Production Engrg (AVT)
E Engine Engrg. Engine Product and Mfg. Engrg.-Dearborn
F Electronic Engineering Operations (ACD)
G Engine Engrg. Engine Product and Mfg. Engrg.-Merkenich
H Climate Control Opts, (ACD)
J FCSD Parts & Accessories Engineering
K Import Release Section
L FCSD Power Products Engineering
M Performance Operations, Special Vehicle Operations
N Not Assigned
O Outside-Used by outside Suppliers who use Ford structure
P Trans & Axle Product and Mfg. Engineering (Auto Trans) Dearborn
Q Diesel Engine Engineering
R Trans & Axle Product and Mfg. Engineering (Man Trans) Dearborn
S Light &Heavy Truck Engrg. Truck Special Order Dept.
T Electrical/Electronic Systems Engineering (AVT)
U Electrical and Fuel Handling Division
V Domestic and Special Order Engrg. (Car Special Order & SVE)
W Trans & Axle Product and Mfg. Engrg. (Axle &Driveline)
Y Special Vehicle Programs Group (VCI)
Z Ford Customer Service Div. Products Analysis
1 Small/Medium Car Vehicle Center
2 Large & Luxury Vehicle Center
3 Large & Luxury Vehicle Center
4 Truck Vehicle Center
5 Truck Vehicle Center
6 Not Assigned
7 Trans & Axle Product & Mfg. Engineering – Merkenich
8 Electric Vehicle Engineering (AVT)
9 Not Assigned
I still would like to know what I would need to install a 4r100? I am considering a super charger for later down the road.
One more thing, how do I confirm a trans is a 4r70W (wide) vs. 4r70 with narrower gearing?
Thanks
First Digit = Year
X 1999
Y 2000
1 2001
2 2002
3 2003
4 2004
5 2005
6 2006
7 2007
8 2008
9 2009
A 2010
B 2011
C 2012
D 2013
E 2014
F 2015
G 2016
H 2017
J 2018
K 2019
L 2020
M 2021
N 2022
P 2023
R 2024
S 2025
T 2026
V 2027
W 2028
C1 Transit/v184
C2 Econoline
C3 Medium Truck
C4 Heavy Duty L
C5 Mustang
F1 Taurus
F2 Windstar
F3 Continental-FWD
F4 Sable
F5 Villager
F6 T-Bird
F7 EN158
F8 Martin
L1 Expedition
L2 Explorer
L6 Aerostar
M1 Tracer
M2 VX62FWD MPV
M3 Courier J97
R1 Aston
R2 Falcon
R3 Mustang
R4 Scorpio
R5 Fairlane
R6 LTD
R7 Not Assigned
R8 Jaguar X200
R9 Mark VIII
S1 Aspire
S2 Contour
S3 C212MAV
S4 Escort/CW170
S5 BE146
S6 Fiesta/BW153
S7 Mondeo/CW132
S8 Probe/SW164
S9 Mystique
W1 Town Car
W2 Cougar
W3 Grand Marquis
W4 Lincoln LS
W5 EW171
W6 T-Bird RWD
W7 Crown Vic EM114
W8 Jaguar X100
W9 Jaguar X300
X4 Jaguar X400
B Not Assigned
C Chassis Operation
N Not Assigned
6 Not Assigned
9 Not Assigned
Thanks
Quadhole
04-02-2019 09:20 AM
Meatco1
05-22-2007 03:58 PM
