How much does your 5.4L weigh?
10,280 pounds when it leaves driveway.
( I know hard to believe. 2003 f 350 in a motorhome mounted rv) Over 100,000 miles. Has oil changed every 3-4 thousand.
Has a hard time getting out of its own way, but once you get it up to speed purrs right along. goes up mountain passes OK, So far with problems are one axle tube, starter and a lot of gas. Average 10.5 mpg. Only thing that is re-occurring problem is the right rear side sway bar rubber bushing. Eats thru them, rubber or plastic, can't figuire out fix for it, so just replace it about every 10K.
