Decoding f-250 diff.
Old May 25, 2013 | 02:31 PM
SEH43's Avatar
SEH43
Hi I'm new so be nice.
I just bought an 86 F250, 6.9L, c6, 3.55:1 ratio, full floating axle. The cert sticker on the door post is unreadable, so how do I dine the axle capacity?
It has a 12 bolt cover and the tag reads:
Top line: V127A
Lower line: 55 10 2 6B20
Any help is appreciated.
Steve
Old May 25, 2013 | 02:40 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You have a 3.55 ratio Sterling (Ford) 10.25" rear.
About 3 1/2 quarts of 80/90 GL5 gear oil.
There is no 'L' in the bottom line before '.55', so you don't need additive.
Old May 25, 2013 | 02:48 PM
SEH43's Avatar
SEH43
Decoding F250 diff
Thanks for the e mediator reply.
Can you tell from these no. What the gross axle capacity is?
Old May 25, 2013 | 03:02 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sorry, I misunderstood. I thought you meant fluid capacity.
That would depend on the springs and length of chassis.
You say you can't read the door tag, but the one in my truck says (rear) GAWR 6084 Lbs
Old May 25, 2013 | 03:08 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
'6B20' is built on Feb 20th 1986
'V127A' is a 3.55 10.25" for an f-250&350 pickup.
BUT it also says it is limited slip!
Perhaps the '3L' portion of the stamp is under the nut holding it on.
http://www.fordification.com/tech/rearends_ford17.htm
http://www.foureyedpride.com/joom/in...d=24&Itemid=40
Old May 25, 2013 | 04:37 PM
SEH43's Avatar
SEH43
Thanks again for the info. The trunk is a std cab long bed, rear springs have 5 leafs with with a single leaf overload.
Old May 25, 2013 | 05:04 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Our trucks are the same configuration, 133" WB.
I would think that 3 tons is about right for yours too.
BTW, welcome to the FTE forum!
Old May 25, 2013 | 05:17 PM
SEH43's Avatar
SEH43
Thanks a lot. You guy aware a great resource. This truck has MANY issues so I will be asking for lots of help.
gila_dog
Mar 16, 2016 04:11 PM
Sweet Christine
Nov 26, 2006 06:48 PM
dmpiowa
Oct 1, 2003 08:26 PM
hagedornmj
Jul 20, 2003 06:53 PM
Stanwmc
Aug 31, 2002 12:19 AM
