New to me '85 F250 Explorer 4x4
Old 05-27-2013, 10:47 AM
rsh27921
rsh27921 is offline
rsh27921 is starting off with a positive reputation.
I just got the same truck last october and even same color...love it..have the same gears and she will wind up pretty tight over 55mph. Needless to say, I have no regrets on getting it and don't forget, she'll pull past anything but a gas station. But I must say that if you can keep your foot out of the gas, it's not too bad. Oh yeah, check on swapping to a 3g alternator..just had mine go up last week..not fun and the new alternators are much safer! Happy motoring and welcome!
Forgot to ask if you had the vinyl or cloth seats? I bought my truck with blue bronco buckets and want to make it stock again and am looking to see what kinda bench they had in them..could you snap and post a pic?
Old 05-27-2013, 11:11 AM
ArdWrknTrk
ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
'Explorer' is an XLT, it would have cloth seats.
Old 05-27-2013, 12:01 PM
88LX5.0H's Avatar
88LX5.0H
88LX5.0H is offline
88LX5.0H is gaining momentum as a positive member of FTE.
Yeah 3G alts are much safer and have a much higher output. You could then run a nice electric fan with a 3g. That would net you a little bit more power and more fuel mileage. It won't be a significant gain since the 460 already has so much torque, but every little bit counts with a big block lol
Old 05-27-2013, 09:35 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Originally Posted by quakerj View Post
Here's the sticker off the door pillar. Any helpful info that can be deciphered from the codes or VIN would be most appreciated.
1FT H X26 L 2 F K B52483
1FT = WORLD MFR. IDENTIFIER = Ford Motor Company, USA, Truck, Complete Vehicle
H= BRAKES/GVWR CODE = CLASS G = 8,501-9,000 LBS.
X26 = SERIES CODE = F250 CREW CAB 4WD PICKUP
L = ENGINE CODE = 7.5L/460 cid 8-CYL GASOLINE-POWERED, 4/B
2 = CHECK DIGIT (IGNORE, FOR FOMOCO USE ONLY)
F = MODEL YEAR CODE = 1985
K = ASSEMBLY PLANT CODE = KANSAS CITY
B52483 = NUMERICAL SEQUENCE OF ASSEMBLY
EXTERIOR PAINT COLORS
9N = MEDIUM DESERT TAN METALLIC ACRYLIC LACQUER
8Q = LIGHT DESERT TAN ACRYLIC LACQUER
DSO 76 = LOCATION OF ORIGINAL-PURCHASING DEALER = DENVER
F0108 = 108 lbs. of accessory equipment (e.g. plow) can be placed on the front axle without requiring recertification
T0242 = Total weight of accessory equipment front + back w/o requiring recertification
WB 155 = 155" WHEELBASE
TYPE-GVW X268 = in 1985 this means... PICKUP - SUPER CAB, 8,600 LB. GVWR, F250, 4WD
BODY KHM =
K = MATERIAL AND TYPE OF SEAT = CLOTH AND VINYL FULL-WIDTH BENCH SEAT
H = TRIM COLOR = TAN
M = BACK OF CAB EQUIPMENT = M = SUPER CAB W/STYLESIDE PICKUP BOX (TYPE 99)
TRANS P = BORG WARNER T19 4 SPD. MANUAL
AXLE 35 = 4.10:1 RATIO, 6,200 LB. CAPACITY, BUILT BY FORD, NON-LOCKING
TAPE = OPTIONAL TAPE STRIPES TYPE
SPRING 7 K =
7 = FRONT SPRING IDENTIFIER - E0TZ-5310-S REPLACEMENT PART NUMBER
K = REAR SPRING IDENTIFIER - E3TZ-5560-T REPLACEMENT PART NUMBER (later superseded by E7TZ-5560-A)
The parts book has no real information on springs other than replacement part numbers, you might Google the numbers for more info if you're interested
Source: FoMoCo 1980/89 Light Truck Master Parts Catalog (available on CD from hipoparts.com)
Old 05-28-2013, 02:53 AM
quakerj's Avatar
quakerj
quakerj is offline
quakerj is gaining momentum as a positive member of FTE.
As some had posted, they're the tan cloth seats, wasn't lucky enough to get captain's chairs, though I'm not sure if that was even an option in this particular model.
The second pic was at night, so the image quality is less than stellar because of the crude cellphone flash.
Raleigh1
1978 - 1996 Big Bronco
682
03-18-2016 01:29 PM
RussEx
02-09-2015 09:05 PM
Snowseeker
08-04-2014 08:21 PM
AAK625
2004 - 2008 F150
10-11-2010 07:08 PM
Casey_78
32
01-04-2009 08:39 PM
Quick Reply: New to me '85 F250 Explorer 4x4
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
