Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
A couple of vins/warranty plates i need decoded
Old 05-16-2013, 05:15 PM
Dieselzuk's Avatar
Dieselzuk
Dieselzuk is offline
I am looking for a 5 spd with OD trans mission from a 79 'ish F600..I have came across 2 trucks..but not sure if they have od.
The vin for the first is
F60ccdk2492...trans code 4
The second one is
F61ecx41510...trans code 0
Thanks for all the help!!
Old 06-05-2013, 11:30 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Dieselzuk
I am looking for a 5 spd with OD transmission from a 79 'ish F600..I have came across 2 trucks..but not sure if they have od.
The vin for the first is F60CCDK2492...trans code 4 / The second one is F61ECX41510...trans code letter O
F60 = F600 2WD / C = 370 2V or 429 4V (both listed under C) / C = Oakville Ontario Canada Truck Assembly Plant / DK2492 = 1979 / 4 = Clark model 280VO 5 Speed Overdrive.
F61 = F600 2WD / E = 361 2V or 4V FT engine / C = Oakville Ontario Canada Truck Assembly Plant / X41510 = 1977.
O refers to two different 5 speed transmissions: Fuller model T905B 5 Speed Direct or New Process model 542FL 5 Speed Direct.
Old 06-05-2013, 02:58 PM
Dieselzuk's Avatar
Dieselzuk
Thank you sir!
Magnus29
03-16-2016 03:41 PM
65F100390
32
10-28-2010 05:53 AM
faulkz
03-14-2008 11:45 AM
C-700
05-15-2007 10:48 AM
gfinch1050
01-15-2007 12:37 AM
Quick Reply: A couple of vins/warranty plates i need decoded
