Easy-out stuck in head/injector port
I've tried drilling through easy-outs, never successfully. The bit will most likely wander over to one side and damage the head. If anything I'd try to center punch it so the bit will have less of a chance of wandering, and use a left handed bit.
There may not be an easy fix here. My suggestion to you would be to pull the head and pay a machine shop to fix it, or see if the local junkyard has a head available (worst case scenario, depending on cost).
I would concentrate on getting the sleeve out of the head, not the easyout out of the sleeve. Someone else was having trouble with this and they were told to use a slide hammer and a old injector with the head threads ground off. What I would do is try to force something in between the sleeve and the easyout, then use that try to pry or slide hammer the sleeve out.
The pre-chamber goes straight into the cylinder through a small-ish hole. There is no access from the pre-chamber to the valves.
What could stop me from just punching the easy out the rest of the way through?
If there are still the lower threads that the injector can grab onto using a ground injector and a slide hammer, go that route. Can't tell if that's the whole of what's stuck in there in the pics...
I suppose I'll have to just remove the head and send it up to a local machine shop.
I wouldn't knock it through just for the possibility that the easy out may already be resting on the chamber, that may be what stopped it from dropping all the way through.
If you pull the head, flip it over an tap it with a rubber mallet, you may get lucky if it's not jammed in there it may drop out.
Unfortunately I know nothing about welding *wish I did*.
Just like /u/Chevy_Eater, I'm never using an easy out on something as critical as a head again.
#29
That is a fine idea, my friend. What if I were to heat the head up with a propane/butane torch, and spray liquid duster to shrink the easy out? Any risk of cracking the head?
#30
just freeze the sleeve. heating/freezing parts is all about thermal shock. you want something to either grow, or shrink faster than whatever its touching if you heat the head there is so much mass there that there is nowhere for the heated material to grow to, so you will actually be shrinking the bore. the sleeve on the other hand should shrink when you freeze it. id try that with the slide hammer trick. you gotta try to get it as cold as you possibly can, before the head has a chance to cool down.
