Injector Nailing or Valve Tap, but different
Old 05-18-2013, 03:33 PM
Hawk180's Avatar
Hawk180
Hawk180 is offline
Hawk180 is starting off with a positive reputation.
OK guys, here's one that will have you scratching your heads. My 01 7.3 has a tap in it that gets louder after it warms up. Not enough to cause alarm, but annoying nonetheless. It sounds like an injector nail or valve tap coming from #6 or #8 position. OK that's the easy part. Here's the interesting part. When it is rainy and cool, it does not do it. Only when the weather is clear and sunny. If it is clear it does it night or day, but if it is raining, it does not do it regardless of the temperature. I'm lost on this one. It is raining pretty steady here today. I drove to the post office (About 6 miles one way) and back and it ran perfectly smooth all the way there and back with absolutely no tap whatsoever. Yesterday, it was sunny and about 65 degrees. It tapped all day after it warmed up. I would just like to get an idea of where to look.
Old 05-20-2013, 03:13 PM
Hawk180's Avatar
Hawk180
Hawk180 is offline
I guess this one did stump everyone...
Old 05-20-2013, 03:38 PM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
jeffreyt is a splendid one to beholdjeffreyt is a splendid one to beholdjeffreyt is a splendid one to beholdjeffreyt is a splendid one to beholdjeffreyt is a splendid one to beholdjeffreyt is a splendid one to beholdjeffreyt is a splendid one to behold
Hmm... Does it change sound or frequency with engine speed?
And are you sure it isn't just masked with the rain? Maybe something on or near a belt or the fan that is tapping, but sticks down when it gets wet
Old 05-21-2013, 11:50 AM
spongecop's Avatar
spongecop
spongecop is offline
Semper Fi
spongecop is gaining momentum as a positive member of FTE.
My 01 has a tap at idle which goes away with RPM. I assumed it was normal. No visible exhaust leaks
Old 05-22-2013, 06:08 AM
Tugly's Avatar
Tugly
Tugly is offline
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
My engine is more noisy at full temp. It's the way the HEUI system responds to the oil viscosity. I have had loose injector bolts and tightening them up quiets things down. Air in fuel makes noise, the Hutch mod helps a lot. Fuel additive (I use Motorcraft) helps sometimes.
Tugly
12-31-2016 12:13 AM
jamays
16
11-21-2016 12:23 AM
PapaBearYuma
31
09-20-2016 04:13 PM
drptop70ss
19
09-02-2015 05:25 PM
polish tom
06-03-2014 05:54 PM
Quick Reply: Injector Nailing or Valve Tap, but different
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
