Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
2003 7.3 DIESEL KEEPS CUTTING OUT ON ME WHEN HOT
Old 05-17-2013, 04:18 PM
CARMINES
CARMINES is offline
CARMINES is starting off with a positive reputation.
TRUCK RUNS GREAT FOR 15 MINUTES THEN SOUNDS FUEL STARVED AND CUTS OUT LIKE IT HAS NO FUEL AND ALL BUT DIES. FILTERS ARE FINE . INJECTORS ARE FINE . COULD IT BE SOMETHING IN THE FUSE PANEL GETTING HOT? PLEASE HELP
Old 05-17-2013, 04:21 PM
Crewcab Turbo's Avatar
Crewcab Turbo
Crewcab Turbo is offline
Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.
Is your oil level good. How oil is your oil? What type oil you using?
Old 05-17-2013, 04:24 PM
CARMINES
CARMINES is offline
YES OIL LEVEL IS FINE.
CARMINES
CARMINES is offline
MY MECHANIC THAUGHT IT WAS SOME SORT OF VALVE SO HE BI PASSED IT AND IT STILL CUTS OUT
Old 05-17-2013, 08:27 PM
Bonanza35
Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Are you at 1/4 tank? And have you done the intank mods? It could be a fuel thing if that's the case.
Old 05-17-2013, 08:41 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Fuel pick up screens ? Just a thought !
Old 05-17-2013, 09:07 PM
CARMINES
CARMINES is offline
Where are they located
Old 05-17-2013, 09:25 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
If your truck has them they are inside the tank , inside the fuel pick up assy. The foot and bottom come off and there are 2 small screens inside . They are a fine mesh and get plugged with trash and bacteria . I have cleaned out many . Most here recomend modifying the pick up assy . Serch it . I think , Hutch Mod . My shop just cleans the screens and tank .
Old 05-17-2013, 09:37 PM
sand_fiend's Avatar
sand_fiend
sand_fiend is offline
Work in Progress
sand_fiend has a very good reputation on FTE.sand_fiend has a very good reputation on FTE.sand_fiend has a very good reputation on FTE.
Check the IPR valve. see if the brass nut on the back is on and tight.
also check the ICP valve. un-plug it and see if there is oil in the inside of the plug it's self. usually a truck that dies when hot has a IPR going out
Old 05-17-2013, 09:38 PM
Tailgate77478
Tailgate77478 is offline
Tailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud of
The reason they are asking if you are below 1/4 tank is that the pickup foot is known to break, and therefore, starts to suck air instead of fuel...causing the truck to cut-off. When it's sitting there and getting primed by your fuel pump, it will start and run for a bit. Although, 15 minutes is a fairly long time for a broken pickup foot...so it's more likely there is blockage in your screens in that scenario.
Try to get an air hose to blow down the fuel line from your pump toward the tank. Short bursts. And make sure your fuel cap IS OFF when you do this. That may blow debris and blockages back into the tank and clear it up for the time being.
What about your CPS? Has it ever been replaced? If not, this could be a simple CPS problem.
Lastly, PLEASE DO NOT USE ALL CAPS. PEOPLE TAKE IT AS IF YOU ARE YELLING AT THEM.
Old 05-17-2013, 09:48 PM
buckt88
buckt88 is offline
buckt88 is starting off with a positive reputation.
You could have water in your in the bottom of your fuel filter to just a idea i had a7.3 idi. And it would cut out if it had a little water in the bottom of fuel filter
Old 05-17-2013, 09:56 PM
Tailgate77478
Forgot to say in my original reply...DITTO to this comment. Your IPR nut if loose or missing will cause all sorts of crazy issues, including it dying. On mine, it was when I tried to accelerate from a complete stop. Once I put the nut back on (fell into the valley), it ran like a champ.
Old 05-17-2013, 10:47 PM
mueckster's Avatar
mueckster
mueckster is offline
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Loose nuts are known for causing all kinds of problems. Don't overlook the one behind the steering wheel. Sorry! I couldn't resist.
Old 05-18-2013, 07:25 AM
Tugly's Avatar
Tugly
Tugly is offline
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
The Hutch mod is a link in my signature below. The quick-disconnects are part of the problem, but they wouldn't likely kill the engine - just make it louder and rob you of power at the top end.
joey101
01-19-2011 08:45 AM
lazaro65
09-29-2010 07:48 AM
jpounders
10-14-2007 08:41 AM
firemedic62dt
1999 to 2016 Super Duty
06-17-2006 04:50 PM
jpmiller
04-19-2005 12:20 PM
Quick Reply: 2003 7.3 DIESEL KEEPS CUTTING OUT ON ME WHEN HOT
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
