what rear axle do i have?
ok i trying to find out what my rear axle in my truck is... I've got a 96' Ford F-250 with a 351, 4X4 E40D tranny, my axle code is 35. All I can find is its a 4.10 ratio open diff and it made by ford. But is it a 10.25 or ???, i would like to have some one put a locker in it but i wanna see what available for my rear end and i need to know what it is... thanks
Sorry to bring up an older thread but this weekend I'm going to look at a possible parts truck to buy and would like to know the what the code would be on the door tag for all gear ratio variations. It is a 1990 2wd f350 460 with 5 speed. My guess would be that it is a 4.10 sterling and from info above it should say 35 on door tag correct? If it is 3.54 or 3.73 what will it be? Info is always appreciated
We have only driven the old truck 4 or 5 miles but she seems to be OK.It does have a little whine between 30 and 40 mph,mostly on the coast side but the pattern looked real clean when I checked it on reassembly.I have had 2 other used gears that I got some noise out of after setup and the others were visibly worn.The noise isn't bad just noticable I guess.It had pinion bearings REAL loose when we got it so I'm thinking the gear could be worn some.
Welcome to FTE.
10.25 = ring gear diameter in inches.
"Full floater" means the axle does not bear weight. It only transmits rotational force.
A full floating axle supports the weight with the axle housing. The wheel bolts to a hub.
A non-floating, or semi-floating have the wheels bolt to the axle, and the axle shaft transmists rotational force and bears the weight of the vehicle.
A full floater:
http://www.askjeffwilliams.com/uploa...all%20axle.JPG
Not a floater, note how the axle has a flange and studs to mount the wheel:
http://image.off-roadweb.com/f/30877...axle_shaft.jpg
A full floater:
It would be "normal" for that size truck, which is still considered a "light duty" truck. What you can tow depends on what else is going on with the rest of the truck. Auto or manual, SRW/DRW, ratio, springs, other equipment, brakes, tires....
It appears the 10.25" was used in that year F350.
If there is a tag on the axle, post all the info from the tag, and more can be figured from there.
