94 ford F250 7.5L engine
Radio Shack may have appropriate replacements but it isn't likely. They don't carry much in the way of components anymore.
You need to look at the markings on the capacitors. Since these are electrolytics, they should be easy to read. You're looking for the capacitance and the voltage rating. The capacitance will be in micro-farads, marked uF. You need to get replacements of the same capacitance and with a voltage rating at least as high as is marked on the originals. Higher voltage rating is ok as long as it will physically fit in the space of the old one.
I'd recommend going to Mouser Electronics - Electronic Components Distributor to buy the caps.
302flareside1992
18
08-10-2014 10:40 PM
EMD_DRIVER
09-02-2008 05:28 PM
citygator
05-23-2008 08:58 PM
