460 7.5L Ford Truck Engine Lots of Extras! Block Cast D9TE-AB (eBay)
Category: Accessories
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude, Fit, S2000, Motorcycles, Hybrids
Item Condition: IA
Engine: Part suitable for gas truck
You can reply here with questions but the offers have to be made via eBay.
Description as on eBay:
Up for auction is an almost complete 460 7.5L truck engine, block casting number D9TE-AB. This came out of a truck I recently scrapped due to serious rust issues on the body. The engine ran fine although the intake leaked oil into the combustion chambers. The evidence can be seen but didn't damage the engine and is easily cleanable. Almost everything is included except the heads, intake manifold, and the exhaust manifolds. The crankshaft pulley, water pump, oil filter adapter, and engine mounts are not included. The main cap bolts and piston push rods have not been touched and are still at the original torque specifications.
Why it is partially taken apart is I originally planned on putting some bolt on performance parts onto this setup and re-installing it into another truck. However times have changed and I need the money more for other projects. It came out of a 1986 F-350 with 90k on the odometer but the condition of the inside of the engine and the after market engine mounts makes me think this engine was installed at a later date. I did a compression test on all 8 cylinders about 1k miles ago and they all checked out.
The engine is located in Carter Lake, IA (near Omaha, NE). The buyer is responsible for all shipping and transportation of the engine, local pick up is recommended. I do have an engine hoist to assist loading if needed. Sold as-is. This engine is also being listed for sale locally. Email me with questions and happy bidding!
It originally had a Ford/Holley carb and round air cleaner on it. If you meant the stock cast iron intake manifold then the answer is yes.
Jpegg01
83
04-06-2018 11:11 AM
RunninD
10-03-2013 05:59 AM
mustangman
04-16-2007 10:55 PM
know_fear
04-24-2006 10:07 AM
