Sponsored by: Real Truck
Help
Old May 15, 2013 | 12:52 PM
scar450's Avatar
scar450
Help
2012 F-350 6.7 im adding some aftermarket lights,air comp,ect, I need to remove both NEG batt cables, will I loose ALL programing, IE eng hrs,nav,ect...?
Old May 15, 2013 | 02:22 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
I believe everything will still be in the PCM. When I unhook the battery on our 02 V10 it is fine I don't see why it would mess up on a newer more advanced truck. Also I am not sure but you may need to reset radio stations and clock we had to in our 97 expedition but not in the 02 so not sure.
Trav
Old May 15, 2013 | 03:10 PM
mikeismadness's Avatar
mikeismadness
You will not lose engine hours, but I'd count on losin your stations and navigation stuff
Old May 15, 2013 | 03:58 PM
r2millers's Avatar
r2millers
Not sure why you need to disconnect the batteries for those installations. Why not install with the final connection into your fuse box to complete? If you wired incorrectly, you just fry a fuse.
I know the first thing any aftermarket products say is to disconnect power but if you do as above, no worries here.
Old May 15, 2013 | 04:17 PM
Yahiko's Avatar
Yahiko
With the batteries unhooked you will also cause the ECM
to go into a learning process it it not getting any power
for the KAM (Keep Alive Memory) That is where the data
about your driving style and truck behavior is stored.
No need to worry you just drive it and it will relearn.
The milage and engine hours won't be cleared.
If you look you can find a little thing that you plug into
the truck that will (well they say it will) save your programing.
Her is one on Amazon
Computer Memory Saver : Amazon.com : Automotive Computer Memory Saver : Amazon.com : Automotive
Or at Autozone
Memory Settings Saver | AutoZone.com
Sean
Yahiko's Avatar
Yahiko
Silly double post
Old May 15, 2013 | 09:34 PM
scar450's Avatar
scar450
Thanks ALL for info
Lashick
Mar 27, 2017 11:44 AM
dtfanning
Escape & Escape Hybrid
Apr 1, 2016 11:24 AM
Mr. Bill No. Mn
Modular V10 (6.8l)
Jan 3, 2009 07:57 PM
Dealford
General Automotive Discussion
Apr 10, 2004 08:40 PM
1994XL
Electrical Systems/Wiring
Mar 12, 2004 09:54 PM
