Fuel bowl test port size
I am sure it is covered on here hundreds of times, but what size fitting does it take to hook up a fuel pressure testing gauge to the test port on the fuel bowl? I don't plan on installing a full time gauge just yet, just something to use to check the health of my system.
It's #4 ORB(ORing Boss) most hook it up with an #4 ORB to 1/8" NPT if you have a hydraulic shop near you, they should have what you need, if not Clay has them
Riffraff Diesel: Pressure Port Adapter - Straight 1/8 FNPT
Riffraff Diesel: Pressure Port Adapter - 90 deg elbow x 1/8 FNPT
Phil Woolfson
03-14-2014 01:54 PM
