Pre or late 99? still confused.
According to this: "<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
The early99 does not have the AIH like the late99-03.
The early99 has no indicator light showing that "cruise" is on. Late99-03 has a cruise light that will come on when you set the cruise control. " I have a late 99 truck. <o></o>
<o></o>
However, my truck built date is 12/22/1998. According to Gooch's Coolant system write-up, my truck is considered pre-99 (pre-02/02/1999 built engine) and should use a conventional coolant charged with SCA. Am I right? Thx. Erwin<o></o>
<o></o>
Here are some examples so you can know what you are looking for.
On the block stamping....the engine serial number appears horizontal. You are looking for the last 7 digits. In this example the serial number is 1226239
The other stamping that is oriented 90 degrees to the serial number is the last 7 characters of the VIN (MA28086)
That is my understanding at least so I hope it helps.
richdawg
05-27-2012 08:43 PM
