Can the bed foam be removed from first gen Super Duty?
Living in CT I am dealing with the same rusty bed most New Englanders do. I have found an older new take off bed from an '05. Does anyone know if the foam can be removed with the bed side on? Is there a possibility to dissolve the foam chemically without paint damage?
Its the foam Ford put inbetween the inner box metal and the outer boxside, it traps moisture and salt inbetween the two metals and rusts it from the inside out. I have seen a thread or two on hear about removing the foam but it is usually when the outer bedside is so gone that you can cut the foam out from the big rust holes. I dont know about dissolving it but it is an interesting Idea...
I'm assuming you would have to remove the inner fender which can just bed glued back on, i had my bed rust through twice and the second time i had the quarters replaced and the foam ripped out. While the inner fender is off you might as well coat it all in POR15 and you will never had a rust issue.
Fluid film sells a hose that might do the trick. I do not have rust showing on the outside yet. But, I have some rust pushing the metal apart in some small areas on the underside of the inner fender. Here is a link to the hose and video.
Fluid Film Spray Wand
FordFETruck
06-20-2012 01:09 PM
MYTRUCK
12-20-2009 08:35 PM
