Dana 60 Swap
Dana 60 Swap
Well I just scored on my Dana 60 for My SAS swap on my 1994. The wife and I dove from Seattle to Portland to pick up this diff that was pulled from a 1995 unlifted f350, 4:10 gears. $750.00. The only thing I was disappointed about was the seller said over the phone that he had the driver side lower spring plate, but he could not find it when I got there. Said he would look again and ship to me,but I am not holding my breath. Had the breaks, rotors, lockouts and steering still attached and all looked in good shape. No other parts were available for the conversion. Compared to everything else I have looked at on Craigslist, it didn't seem like a bad deal. Since I have to swap the gears out for 4:56 ratio to match the rear, I could probably sell the 4:10 set and also the 4:56 that Im currently running in my Dana 50 TTB.
I still need to figure out which f350 leaf springs to use to bring my front up to match the rear. The truck currently has 4" lift brackets bolted and welded to the cross member, and a 5 pack of leafs over the axle tubes. Overall it looks taller than just a 4" lift. Wish I could figure out how to upload pictures? From what I have read I still need to find a f350 driveshaft, track bar and drop mounting bracket, driver spring pad and drop f350 pitman arm.
I know SKY sells a RSK kit for these conversions but for now I think I will try to stick with a spring lift.
Happy to have finally gotten started on this.
Received 3,090 Likes
on
Been reading up a lot about all the upgrades available for the Dana 60 axle and guy could really drop alot of money in one of these making it as bullet proof as possible. One thing I would like to do for sure is upgrade the knuckle to a 96-97 model, so I can run the bolt on style calipers instead of the pins. Does anybody know of a source for balljoint knuckles. Many upgrades for the Kingpin but not much for balljoint. High steer would be nice but not necessary, since I will not be lifting over 4".
Thanks in advance.
Thanks in advance.
vinster888
07-22-2009 07:40 AM
The Runt
08-18-2003 07:51 PM
