Stereo shuts off only while driving
Old 05-08-2013, 11:06 PM
bmacky14
bmacky14 is offline
bmacky14 is starting off with a positive reputation.
I got a 86 f-150 4x4 300 inline 6 4 speed standard my stereo works fine except when I start driving it shuts off and on every 30 seconds
Old 05-09-2013, 02:11 AM
joshofalltrades
joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
is the stereo factory or aftermarket? it sounds like loose wiring that makes contact when it wants to. if its aftermarket, i would bet a previous installer didn't know how to make proper connections and did the infamous twist-n-tape connections.
Old 05-09-2013, 02:14 AM
bmacky14
bmacky14 is offline
It's an aftermarket jvc bought at visions and installed by visions
Old 05-09-2013, 02:20 AM
joshofalltrades
i've never heard of visions, but i'll assume they're a reputable store in your area. even so, it is possible that they made a mistake on a connection somewhere and thats causing your problem.
does it fully reset itself like when the battery has been removed, or only do the normal thing like when you turn the key off?
almost all stereos have one wire bringing power from the battery and another bringing power from the ignition switch. if the battery wire is losing connection, it'll do the full reset like when you disconnect the battery, whereas the ignition wire will only act like you turned it off and back on.
if that tells you its on the switched wire that you have a problem, leave your turn signal on next time you drive it, and see if the turn signal dies along with the radio. if it does, then you have a problem in the ignition switch, as these often develop an issue where accessories don't want to come back on unless you wiggle the key back a bit after starting.
Old 05-09-2013, 03:31 AM
oneowner83
oneowner83 is offline
oneowner83 is gaining momentum as a positive member of FTE.oneowner83 is gaining momentum as a positive member of FTE.
Could be a defective radio
Old 05-28-2013, 08:37 PM
Anger ranger
Anger ranger is offline
Anger ranger is starting off with a positive reputation.
My truck is doing the same thing right now . Haven't fixed it yet but the alt belt slopes when it does it and voltage droops don't know if it is it but an idea
Old 05-28-2013, 08:39 PM
bmacky14
bmacky14 is offline
I got mine fixed it was the ground from the back of the engine block to the fire wall
Old 05-29-2013, 03:40 AM
joshofalltrades
sounds like some kind of massive electrical draw is pulling your whole system down. inspect your alternator wires and other wiring near the battery, it may be that something is shorting to ground.
my mom's car did something similar for awhile - voltage drop and alt belt slipping - the culprit was the alternator output wire getting into other wires. we didn't diagnose it until after the whole harness fried
bmacky14
Electrical Systems/Wiring
05-21-2013 05:12 PM
mudlakemike
2004 - 2008 F150
02-22-2011 11:16 AM
arniek
1997 - 2003 F150
12-23-2010 05:58 AM
explorer04
12-27-2005 08:55 PM
arcturner
22
12-10-2004 07:53 PM
Quick Reply: Stereo shuts off only while driving
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
