Major power loss after egr delete
Ever notice how you can UNDO the marmon clamp Bolt and the clamp still hangs on there Tight as Hell and needs some persuasion with a hammer and screwdriver to get the clamp free
But it probably pulled the joint together and sealed it pretty good before the Clamp broke
Even the Marmon clamp would help hold the joint together even when broke
Over time it might have rattled loose and lost the seal IDK
I dont know how it could build 20psi with a Massive exhaust leak when on most these trucks a small leak will cause Huge problems
Mosst the time a small exhaust leak the truck cant get out of its own way
The exhaust smell was overwhelming though... LOL
If the truck ran fine befor the EGR Deleate I doubt the Bolts stretched
If the headgaskets was the problem it would PUKE
You can put a pressure gauge on one of the Small Coolant lines at the Degass Bottle then drive it Pressure should be 8-12 psi for Good Any Higher PSI NO GOOD
did they smoke the intake check for leaks
Get any gauges Yet???
Now this is Just my Opinion so it DONT MEAN Much But The Problem is these Mechanics None of them Care to spend a Day to track whatever it is Down
Exactly what I am getting at here^^^You have an Exhaust leak at one of the Exhaust uppipe joints
I suspect this is why you cant build Boost PSI and VERY VERY VERY Common after this type work
Exhaust smell in cab,No Boost,and Gutless truck all go Hand in Hand with an Uppipe exhaust leak Normaly at the Ypipe to Turbo Joint
Slim chance the Exhaust Downpipe leaks at Turbo
If this leaked you would only get the exhaust smell and ZERO Drivability issue so I dont think its the downpipe
A bad temp sensor would cause this fan issue to
Do you have the butterfly valve in the intake on this truck for the EGR? You may have added a tune to disable that I missed. Anyway. In addition to the other things you are checking you might take a look at it. I had to run for a short time with stock tune and no EGR. Found it would shut down the valve at the strangest of time. I removed the butterfly from mine so there is no doubt it will not close off.
May be a shot in the dark. But I think you should consider.
I vote for a blockage or maybe a sensor
I did the BPD kit a few months back. After the install I had a leak at one of my clamps; and it was pretty significant. I was still able to build above 2 psi, but it didn't run very well. You could definitely hear the leak and feel it at one of the clamps. I suppose if you haven't had the truck long (or diesel long), you may not not know the sound change. I'm still having a hard time with only 2 psi being a leak that can't be felt (don't forget to check at the manifolds where you loosen each side to align the pipes at the turbo).
This may sound like a stupid question, but where there any rags used, stuffed in anything like the cooler tubes or anything else to keep stuff out (that may have been forgotten)? If it's not a blockage, I'd go with one of the sensors every else recommended. I would probably put my old turbo back in or at least the original VGT solenoid. Now you have additional variables. The replacement VGT can cause issues. During my BPD install I also did my turbo. The solenoid that came wiht the turbo didnt work quite right and had little surges (put the old solenoid in and it fixed it).
They sell ScanGaugeII at AutoZone around $$160.00
SGII will give ability to check all sensors on the 6.0L for engine and even some trans
Now they Sell a Tool called AutoEnginuity with Ford Enhancements its the Best thing Going for a DIYer
Its Around $$360.00 from Clay at RiffRaff Diesel
Check it out here Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
Click ME^^^^^^^^^^^^^^^^^^^^^^
Iv heard great things about them AE with ford enhanced!!! You will be able to check ALL DTC Engine--Trans--ABS Brakes EVERYTHING for Codes!!!!
It will also Allow you to control the VGT for turbo for testing
It will also Allow you to control the IPR for the HPO
Allows a Buzz test for injectors
Will do Cylinder Balance testing if you ever have a Week injector thats Not all the way Dead and should pick it up
Im shure it does Lots More
Just all Kinds of stuff so something to think about anyway
We may see the problem with SGII as well but thats just a Gauge so good to always have in the truck
The AE is Software for your Laptop so it has a Cable that Hooks to the OBDII Port But most folks dont keep a Laptop in the Truck
#30
Your going to need more than a Code Reader at this point
We got to see Live Data!!!
Keep scanning for codes one may pop at any time but may take a fair amount of driving to set a code and some may have to Fail for Multiple drive cycles
We have all Ford Sensor values for all engine sensor/actuators and a criteria to test with
but you have to see live data at a minimum
ScanGaugeII or Dashboss or Torq App will show live data sensor values they are just gauges that plug into the OBDII Port you cant control engine with these
You may figure it out with that^^IDK or with AutoEnginuity Ford enhanced Package would be the Best and Might be neccasery for your problem
If you have a smart phone I think the guys use the Torq app and set it up for around $30.00
If you could find a Good mechanic that Knows the 6.0L well he could test it out and figure it out for you
But Im thinking your able to do the EGR Deleate so you could fix it you just need a decent scan tool at this point
If you would rather have a Mechanic do it then it would be good to tell us where you are located and you can also post in your area chapter to find a decent mechanic
