2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Coolant flush
Old 05-20-2013, 08:34 PM
thinksnow's Avatar
thinksnow
thinksnow is offline
Coolant flush
Flushed out the Expy tonight, it left me a little confused. I drained and collected the old coolant. Topped off the system with water and ran the truck for a while with the heat on hi, then drained the system again. I repeated the process a third time. When I added the new coolant I could only get it to take 7 qts. It should take far more then that. That is going to leave my coolant strength far to low. Should I go for a long drive, come back and drain off more mixed coolant and replace it with pure coolant to increase the ratio. ???
Old 05-21-2013, 03:28 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Well, I am betting that after your drive you didn't leave the heater on and when you drained it, the system left a qt or so within the heater system....really not that big of an issue....
What I would suggest is picking up a coolant bulb type tester (about $12) and test the freeze/overheat level....I think you will be surprised at where you are at....then if need be, drain a little and add 100% coolant- that should bring you up to where you need to be.
jetedwards
11-02-2020 12:25 PM
Berriemaas
1999 to 2016 Super Duty
09-14-2017 07:09 AM
Padlock
10-05-2014 08:47 AM
thinksnow
2004 - 2008 F150
05-23-2013 10:03 AM
Firefighter 1406
12-20-2010 09:13 PM
Quick Reply: Coolant flush
