Rebuilt carb but now not working???
  #31
Old 05-08-2013, 11:05 PM
fixnair's Avatar
fixnair
fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
Why don't you try this just for grins. While you are cranking the engine, open the throttle plate and squirt some WD40(not starting fluid) down the carb. It should run as long as you spray the stuff. If it behaves the same then I would look elsewhere. If it runs good then I would look at the carb or fuel pump.
  #32
Old 05-09-2013, 06:12 AM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Sounds to me as if the needle valve at fuel inlet is not moving freely - sometimes. I'd pull it and look for dirt/rust/bits of old fuel pump diaphragm, whatever. It could well be a new problem.
  #33
Old 05-09-2013, 08:12 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Some of the new replacement fuel pumps are known to put out too much pressure. I'm surprised they haven't warned you of this on the Ford Barn.
  #34
Old 05-09-2013, 08:00 PM
49m47's Avatar
49m47
49m47 is offline
49m47 is gaining momentum as a positive member of FTE.
2 things. First, I recently purchased a NOS 1949 fuel pump still in the original box. On the box it stated that the unit is shipped with all the Head bolts lose. Referring to the 8 machine screw the go around the diaphragm. I doubt that it has anything to do with your situation but I thought I would point it out.
Did you inspect your float? It almost sound like you have a hole in it and it slowly fills up. Then it sinks and opens the needle valve and you get gas all over.
  #35
Old 05-10-2013, 04:59 AM
CraigerF100's Avatar
CraigerF100
CraigerF100 is offline
CraigerF100 is starting off with a positive reputation.
you mentioned you adjusted the float height, maybe knock her back down a notch and take another joy ride to the car wash
  #36
Old 05-20-2013, 09:22 PM
49m47's Avatar
49m47
49m47 is offline
How did this finally turn out? Are you up and running?
F350dog
32
09-24-2015 01:00 PM
jawroper
05-26-2015 04:29 PM
martyanderson10
Large Truck
03-15-2015 10:38 PM
tdawglp
11-18-2011 06:22 PM
78-250Super
07-29-2006 11:27 AM
Quick Reply: Rebuilt carb but now not working???
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
