I have a 2006 F250 and it has the stock keyless entry. I would like to have remote start system as well. I know I can buy an aftermarket system, but I'd prefer to no cut any wires. does anyone know if it is possible to add on the OEM remote start system that may have been used on a superduty or excision of this vintage? and if so, is it a plug in type installation? or do you still have to cut and splice the stock wiring harness. thank you all in advance for you help and knowledge
I don't believe there was a factory alarm or remote start offered in 2006. There was a Ford branded system, but it was a dealer installed item. Did it require splicing wires, or was it plug and play??? This I do not know. Can you still buy that system? This I do not know.
