Tires provide THE contact with the road. 8k lbs plus the lives of your passenger(s) depend on them. So do others on the road. Buy E-rated tires.
Would you buy the discounted parachute?
Kinda an apples and oranges kinda thing.
The LT265/75R16 D 120S BFGoodrich All-Terrain T/A KO tires are good for 3086# more than enough for your Ex. From everything I've read they are fine provided you are not towing heavy.
Well, 265/70/16s are an inch smaller in diameter, and will look really small on an Ex.
I would not put Ds on an Ex anyway. While they may be rated enough in pounds, they will wear much faster than a set of Es.
I would definitely pass on the small Ds.
(I have 265/75/16 Michelins LTX MS2 LRE, and love them. But I want to go up to 285s. Problem is I have 30k miles on them and they still look new. Probably have another 40-50k left in them. Seriously thinking about replacing with 285s and selling these on craigslist for half of what I paid for them.)
D rated tires are rated for far more than the X will weigh, there is no safety issue by using them instead. The critical thing is for them to be properly inflated for the load while not exceeding their max pressure.
I have read quite a bit about tires, but I have never read anything to suggest that the tread compound is softer in lower load range tires. Can you provide a source for this?
Sounds like a myth to me.
Well it has nothing to do with the compound, its just a matter of the tire rolling to the side in the turns due to the lack of sidewall stiffness. No particular source other than many who have reported high rate of wear on Ds and then great wear on a set of the same tires in E. Read through the tire reviews on tirerack.com.
But why would you run Ds over Es anyway? What benefit do Ds provide?
They don't provide any benefit that I'm aware of, my Excursion has new LR E tires. The OP started this thread talking about the great deal he can have on a set. If the deal is good enough I don't see a reason why he shouldn't go for it.
I hear you, but they arent even the right size. If its a good enough deal, sure buy them and sell them and make a few bucks, but I wouldnt recommend putting used tires that are too small with a D load rating on anybodys Excursion.
I sounds like a myth to me too, and the rolling onto the side thing doesn't make any sense either since it wouldn't roll more if any at all than the E's. Also thousands of people are running D's and they are entirely suitable with little or no towing. I ran them for 3 years.
Speaking of myths; rear ends have the greatest database of myths.
Also; I run into super deals on tires sometimes which are tempting but if they are not E's, right size, not too old, and right tread I pass them up. A deal is not a deal if you don't need it.
I ended up owing more than I would have liked to to the gov'ment for taxes... so I've been looking for cheap tires since I'm still running the spare since my flat...
It was those with less than 500miles for $200 or Firestone Steeltex 265/75/16 load E half used for the same price.
Figured with the FS Steeltex history of coming apart at highway speeds and the fact that they're more used that the BFG's might be a better idea...
Maybe I'll just rock the spare for a little while longer...
oh god and here i am running C's!!! mine should explode at any moment.
Yup, prepare for immediate destruction.
Your tires are rated for 2,470 lbs @ 50 PSI. While these would certainly not be my choice, they will be fine as long as you keep them properly inflated and you don't put much weight in the X. Empty with a full tank you are 3,750 lbs on the rear axle, so you can't have more than 1,000 lbs extra on that axle without being overweight.
You also aren't going to be able to achieve the recommended pressures on the door sticker. As long as you keep it light and don't exceed 50 PSI you should have no trouble with these.
In your situation I would buy the BFGs and not look back. Make sure to never exceed the maximum pressure for the tire(which I think is 60 PSI) and don't pull stuff heavy enough to overload your tires.
I replaced 9-year-old Firestone Steeltex tires recently; two after I bought it and the final two in January. The sidewall failed and air was coming through a crack. After 9 years in the sun that isn't bad; I wouldn't hesitate to get a set of them.
