Slowwww crank on start.
on
It could be a bad starter, but it could also be a failing GPCM. You will also want to Ohm your glow plugs to make sure they're all within spec too.
Does it crank up easier if you turn it off after running but quickly crank it back up? If so, it is possible your LPOP needs to be replaced. Make sure to buy a Melling LPOP if you do (about $80).
You're in Flower Mound? One of "The FTE Brotherhood" is from up there...just can't remember who it is off the top of my head.
http://www.ebay.com/itm/281078301261...84.m1439.l2649
http://www.ebay.com/itm/360588611209...84.m1439.l2649
http://www.ebay.com/itm/230926117440...84.m1439.l2649
Jeff
I agree you should load test your batteries,check both ends of all cables...but..I see no purpose in taking the starter to be "tested" at a parts store,you test it every time you go to start your truck,you said its turning slow so as long as all other connections and batts are good,the starter is toast. I was having slow crank issues a while back,replaced the starter and it cranks much better now.I went with a "premium" starter from Oreillys(only because I have a connection there) and so far so good..a year-ish later but it does come with a lifetime warranty..
andydunks
11-03-2014 12:12 PM
Deluxe06
08-26-2012 07:42 PM
colorado_mat
11-30-2009 09:40 PM
MustangMatt96GT
03-29-2009 05:06 PM
