Replacing plugs and wires on V8 Flathead
My truck is missing and I touched a wire and shocked the crap out of me. It's the original 1950 V8 flathead. Can I pick plugs and wire up at a local auto store or do I need to order them from lmc or obsolete ford? Went to oreilly's and they weren't much help.
Does your engine have the cloverleaf-style wire guides? (see pic) The only thing that will fit thru them is the original exposed metal clips. The way around that is to buy a cut-to-fit cable set, thread the wires thru the cloverleaf, then put on the rubber boots and terminals. Almost any universal-fit, cut-to-fit set for a V8 will be long enough.
I know I need new wires cause I had one shock the crap outta me. But I think when all that happened, it vapor locked. Had someone ask me about it at a car show Saturday if I had that happen to me. He explained it, and what he explained is exactly what happened to me. Is there a way to fix that without having to switch to an electric fuel pump?
ssg1957
02-22-2015 10:19 PM
jomoflymo
07-14-2014 08:40 AM
