Coil voltage problem
Generally you can keep an engine running by spraying starting fluid into the carb. I've done this to disprove or prove fuel system problems. The six volt starter should spin the engine well with 12V.
What sputters? Starter making noise? Backfire? Afterfire? Is it firing and kicking back? Have you ever seen the truck run? If not, how long has it been since it ran?
JimG1098
01-13-2008 11:34 PM
RaleighDad66
09-10-2004 08:17 AM
DrFord
05-10-2002 11:23 AM
