97 f250 7.5 PCM identification ford guru's help!!
Old 05-05-2013, 05:40 PM
Texasboy77351's Avatar
Texasboy77351
Texasboy77351 is offline
Ok ill start from beginning, my uncle passed and I got his 97 f250 4 wheel drive 460. Was bought in Washington drove to Cali then drove to texas. Truck was backed into my grandpas driveway and wasent cranked for 6 months. Tryed to crank it wouldn't start... No fuel. Switch for dual tanks was working cause it would change the fuel gauge to each tank. Put a jumper on the rear tank and it fired up. After that no crank... Lol. Fuel pump works no spark. Swapped all parts onto a crown Vic all worked. Read online on this forum that a guy said to unhook pcm if u get spark bad pcm.. Then he said to check for hot and grounds on the harness to make sure it's not bad wiring so it's all good but figured I had bad pcm. Pulled pcm out and the whole outside bottom was rust. Pulled part number called orille's they don't have a replacement with the last 3 at AMD so what pcm do I have? The number is f6tf-12a650-amd. They have like aha at the end. This one don't.
Old 05-10-2013, 11:00 PM
Texasboy77351
This forum sux lol
kfowler.98
07-22-2017 11:14 PM
flipper8787
1997 - 2003 F150
07-21-2015 07:45 PM
khadma
Electrical Systems/Wiring
10-02-2012 07:36 AM
sportsdad
22
06-06-2010 07:38 PM
1997F-350
22
06-04-2010 08:07 PM
Quick Reply: 97 f250 7.5 PCM identification ford guru's help!!
