78000 original miles
Black silicone works best. A real thin dab a few places around should do it. Or if your real good, a real thin layer all the way around. Let it set up before assembly. Make sure to clean glass good both before and after using silicone.
I've removed some where it looked like half a tube of silicone was used.
Silicone the glass to the bezel surround let it set up then assemble. the glass will not move nor rattle.
Let me get this straight,,,,, you guys are worried about a rattle on the dash glass????? Heck, I am wearing hearing protection in my 66 250 so I can stand the rear end whine, the brakes schreech, the exhaust leaks, not to mention the wind tunnel roar around the doors.
Im with Gangstakr I just used clear silicone sealant on mine. I used the outdoor grade so it should stand up to the weather and being in a truck outside. All the ones I have taken apart appear to have some sort of black sticky material holding the glass in.
This is mine installed in the 65 with clear sealant. When the clear dries you have to look hard to see if its even there. Just go lightly with its use you dont need very much. If you ever have to break it just go to a glass shop they should be able to cut you a new one it looks like standard single or double pain glass.
abe
25
05-05-2018 06:58 PM
clintonvillian
02-17-2014 12:46 PM
teched
45
03-21-2012 05:14 PM
