View Poll Results: Is an unserviceable tranny a good idea?
Great idea, should work flawlessly!
9.30%
Not sure.
20.93%
Pipe dream, not practical.
18.60%
Absolute disaster in the making!
22
51.16%
Voters: 43. You may not vote on this poll
Lifetime Transmission Fluid?!?! POLL
If I remember correctly, they said the same thing about the new Explorer when it came out as an 02. It does in fact have no dip stick for the tranny fluid. HOWEVER, you can still change it. There's a plug in the bottom to drain it and then the new fluid is pumped back up into it. Easier, no. But it can still be done.
An automotive engineer at Bendix told me there are heavy duty trucks on the road with sealed tranny's that have already gone 500,000 miles without a change of fluid because they are using a new type of synthetic unaffected by heat. Sealed means no dip stick, no drain plug, no contamination. If a big semi or dirt hauler can do it, why not a light weight expy?
diyster
Escape & Escape Hybrid
01-24-2016 07:15 PM
