Coil issue- 04 Ford F150 XLT 5.4 Triton
Old 04-28-2013, 09:16 PM
handell35's Avatar
handell35
handell35 is offline
Having problems with coil F (6) throwing a check engine light. Been repaired by Ford with a new coil. 2 weeks later threw another code same coil F (6). Went back they said plugs were loose and needed tightened, so they re tightened and sent me on my way. 1 month later threw another check engine light same coil F (6).
Any ideas?
For the time being I switched coil 6 with coil 5 to see if I got a code from 5. Then I could rule it as a bad coil. Drove over 200 miles without an issue as of right now.
Truck details
2004 Ford-F150 XLT 5.4 Triton- 107,xxx
Old 04-29-2013, 12:44 PM
tooldad's Avatar
tooldad
tooldad is offline
Could be a bad connection in the COP wiring harness plug. Also, be aware, I replaced all 8 of mine with Motorcraft COP's one year ago and have just replaced the fifth bad one out of the batch. The bad thing is that I just replaced them last year as a preventative maintenance measure. So it could be a problem with the replacement COP too.
Did somebody say, don't fix it if it ain't broke?
Old 04-29-2013, 02:37 PM
handell35's Avatar
handell35
Thanks for your help man. All I can do is wait now.
gunther32
1997 - 2003 F150
20
07-11-2011 12:36 PM
WildcatDE75
1999 to 2016 Super Duty
03-28-2005 11:43 PM
topdeadcenter
2004 - 2008 F150
08-23-2004 08:34 PM
stateteam
1997 - 2003 F150
05-17-2004 11:26 AM
MAINTAINER
Modular V8 (4.6L, 5.4L)
01-04-2004 10:34 PM
Quick Reply: Coil issue- 04 Ford F150 XLT 5.4 Triton
