Hello everyone I'm going to order this kit ENS-4-4104R for the cab and rad support mounts. Does anyone know if I will I need anything besides the bolts? Do I need to make/buy the washers on top and bottom?
The retainers are the metal washer with the tube on it correct? One on top one on bottom.
yep. If you saved your old ones than all you need is bolts and some large washers to use for shimming the core support. Bushing kits come with bolts and those washers I think. Its been awhile since I had mine.
