Replacing the Oil Pan gasket
I'm hoping to drop the oil pan so i can punch the broken dip stick tube out from underneath. Is there anything i need to do such as lift engine, remover y pipe, or anything like that to get the oil pan out, or can i just simply take out the bolts and wiggle the pan out from under there?
2002 F250 5.4L
2002 F250 5.4L
70-360fe
02-11-2013 10:28 PM
