When it rains it pours , first the rear calipers now the trans.
Can’t believe it , I toasted the trans this morning. The truck has only got 103k miles on it. Sometimes it seems like this thing truck is in the shop more than we drive it. I actually feel sick.. what a way to start the weekend. I’m not one for buying or owning new cars but I’m seriously starting to rethink that. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I had just got on the freeway and traffic was sort of bottled up, just rolling along at about 35 mph and it felt like the truck downshift then slammed back into gear. I've got a jacked up rear caliper that needs to be replaced (was going to happen this weekend) so my first thought was it locked then let go (I was a little foggy this morning). I was only about 3 miles from home so I was able to limp it home. It did it the whole way back , I could also see the trans temp had jumped from 60 degrees to 155. Also from a stop the shift rpms where getting higher and higher.
Got home and pulled the dipstick and even though the fluid was still clear it had a burnt smell to it. The trans fluild also wasn't as red as it was before.
I'm the second owner , the original owner maintained the truck flawlessly. When I purchased it he handed me a file that had the entire history including receipts. When I was shopping for an Ex, I wanted one that was clean , had all the updates for towing done and had low miles. This truck was it other than one thing.. it was a tow vehicle it's whole life. That was the gamble I took and I knew it going it. I just didn't think the trans would go with how well maintained the truck was. I've put 10k miles on it since I bought it ,and had the trans fluid and filter changed when I picked it up. Every oil change I would check the trans fluid and it smelled good and was nice and red. I guess it's just the luck of the draw.
I keep telling myself this is still less than a new vehicle and for the most part the things that have had to be replaced in the 10k miles I've had it are just normal wear items (front wheel bearing, fuell pump, rear calipers) , was going to do the springs this summer but damn this trans is going to be quite a hit. We don't use the X all that much so it would be a waste of money having something new sitting in the drive but dumping money into this thing is starting to change my mind a little.
on
He might have maintained it but pulled a 10k lb trailer through the mountains quite often.
Stewart
Make sure to find a reputable transmission shop.
He probably did, but I was willing to take that gamble because the truck was in such great shape. By the time I bought this one I had looked at so many that were just basket cases. I figured if I had to put a trans in it so be it. Although I didn't think it would be so soon.
Some friends own a shop, I know they do race car stuff, and diesel truck stuff so I'm sure they can do this. Plus they are Ford guys, well as far as their tow vehicles go.
I don't have $5k to spend on a badass trans., wish I did. I spent the long dollar on my old Cummins Ram with a DTT trans.. best money spent.
I'm in Saint Clair Shores, my friends own a place called Driveline Performance. They will most likely be the ones doing it. Open to suggestions though, PM me.
