running truck on front tank with rear tank removed.
Is it possible to run my tuck on just the front tank with the rear tank removed. My rear tank had holes in it and a new one is on the way. Is it possible to run the truck without the rear one without permanently plugging lines and cutting wires?
Is it possible to remove the rear and just run the front? Sure. But when I removed mine, I had no intention of having a rear tank again, so I didn't try to save the lines or wires. I supposed if you're more careful you could probably save them, or just replace them if you put a new tank in.
hail destroyer
06-20-2018 08:52 AM
brucers
10-16-2011 12:18 PM
