1959 f-350 Short bus
Last year my family bought a 1959 ford f350 short bus for tailgaiting. Originally we planned on keeping it the way it was when we bought it but I don't think we can leave well enough alone. It does decent getting around a small college town. However, the rear puts a damper on getting up to a respectable highway speed. And the front end wonders quite a bit at 30 mphs. Plus it would be cool to give the bus some more attitude.
Lately I've been thinking about building a 55-57 chevy truck, but as I drove the bus today it me. We should rebuild the tailgating bus.
In my endless research on 55-57 chevy trucks I have found that front end conversions are a pretty common thing. So why not so it on the bus.
My main concern is. Would a mustang II or crown vic conversion be able to support the weight of a bus. We weighed the truck today and gross weight was 7000lbs. I am assuming the front end is only 15%-20% of this total.
Would also be interested to hear what is a common reared to put under these trucks?
I will let others answer your specific question as I have no experience with the crown vic conversion. However, if you renew the front end and put a steering stabilizer kit on the straight axle steering I am sure it would drive much much better and you won't have the drunken monkey steering you have now. New king pin kit, all new steering tie rod ends, new drag link, stabilizer kit, - see the diagram below. Only about $300 in parts and maybe a weekend job. What rear end does it have in it?
on
I agree with Walston, I would have the front end rebuilt and have the steering box tightened up. It looks like you already have radial tires on the front. As far as road speed maybe try a taller rear tire. It looks as if those rear duals are much shorter that what the oem bias ply tire would have been. Just my opinion.
My 64 has the exact same front end illustrated and drives dead straight on the highway at 70, no slop, it's all about alignment and esp. steering parts not being worn all to hell.
Have someone turn the steering wheel back and forth while feeling and observing the tie rod ends, drag link etc. Any appreciable slop or wear already will increase very rapidly, the manual specifies small tolerances like .005" for this reason. Check kingpins for excessive wear, and wheel bearings for proper adjustment. The steering box can be rebuilt/replaced.
That kind of talk will bring rain! Look out!
Its their money so power to them but for all that is spent on swaps and modifications, such amounts of $$$ would just give me more for upcoming paint jobs & miscellaneous items or put in my retirement. I also might add I have a lot more free time on my hands (& garage space) which I wouldn't if I brought on added modifications & so forth. I went thru that stage when I was much younger when everything had to be chrome & cost didn't seem to be an object (well sort of speaking) on other things.
Steve Harlow
10-01-2017 08:23 PM
staples
03-04-2005 01:37 PM
